Old 12-Jun-2012, 2:33 PM   #6
signals unlimited
You can assume that the coax itself is OK. If the problem is in the transmission line, it is more likely the connections at the antenna or the transformer on the antenna terminals.
I assume that you varified that there is no amplifier in your system, and all connections are ok at the TV set.
I still doubt that the trees are the problem, unless they are large, thick, and directly in front of the receiving end (the narrow end) of the antenna.
