Thread: Reception help
Old 12-Jun-2012, 12:01 PM   #2
signals unlimited
The signal from KAXT is very strong, and the antenna DB4 is more powerfull enough to do the job, so confirm direction and be sure that you are not headed right into a large tree or building, it should aim 117 degrees magnetic. check your connections, and rescan for antenna signals. If all of that fails, try another DTV set or converter box. Perhaps you can borrow a set that has the channel scaned in. Try that.
