The trees should have been full in before last month, so thats probably not your problem.
If your antenna is in good shape, not missing parts ect. check to see if you have an amplifier that may have come unpluged or inoperative. If you have no amplifier, your problem could be resolved by replacing the cable and matching transformer from the antenna to your DTV set. You may have flat leadwire. Replace it with the RG6 coax and a matching transformer. If you need to move the antenna, replace it with a Winegard HD7694P High VHF/UHF.
