Thanks Electron.
I think I will try the C5 instead of the Antennacraft Y10713 that GroundUrMast recommended. The form factor seems much smaller. Based on the reviews it seems like it should pick up 8 and 10 without a problem.
The Winegard HD9095P seems like it's highly directional per the reviews. If I aim it at channel 45, will I have difficulty picking up channel 24 and 35? Also, the form factor seems pretty large. What do you think of using the DB4E that GroundUrMast recommended instead of the HD9095P? Do you think I would still need a preamp per GroundUrMast's recommendation.
Thanks to the both of you for your input.
