Old 11-Jun-2012, 10:46 PM   #1
fitchetm
Antenna/Set-up recommendation, Almont MI
Hey everyone,
I've been reading through the site and trying to figure out the best set-up for me and figured it would just be best to lay the info out there and let the people who know more than me offer some help
I'm located in Almont, MI: http://www.tvfool.com/?option=com_wr...1349d086cd65d1
I'm just looking for the normal channels (FOX, CBS, PBS) or whatever else I can pick up easily (definitely need something good for the kids).
I have a south facing chimney wall that I will use for mounting (at approximately 20ft or I can go higher if needed). No trees for approximately 100ft from house.
One tv for now approximately 20ft from antenna location.. another tv to follow that will be downstairs so.. approx. 50ft from antenna.
So far, I'm thinking of getting the atennas direct 91XG on amazon or the antennas direct DB8 (not sure which one suits my situation better).
Also, Do I need a pre-amp and should I go with a two antenna configuration or a motor mount?
Any help would be greatly appreciated and i'm looking forward to the input.
Thansk,
matt
Last edited by fitchetm; 11-Jun-2012 at 10:52 PM. Reason: Forgot to add info about trees.
fitchetm is offline   Reply With Quote
