Thanks for your responses. attic is wood frame with fiberglass installation. I'll check the material underroof but as i recall, there's no plywood panels under the tiles. I can see outside through the tile's downward curve.
I'm open to mount outside at height about 10-15' as well. Does your recommendation change for outside mounting? Saw on amazon the clearstream4/db8 stated range 65+ miles, do i gain any additional channels with longer range or the Winegard HD7082P/Winegard HD7000R/RCA ANT751 covers all/most of the channels in my surrounding areas?
