Old 31-Aug-2010, 7:46 PM   #30
frank
Originally Posted by Billsmith View Post
CityTv (CKAL-DT) have now received CRTC approval and should be ready to go with some testing very soon as their 100Kw ERP transmitter set up and ready to go on Channel 49. It is using the same panel antenna array as Global CICT-DT so if you receive Global well, then you should also receive CityTv equally well or better at double the ERP.
CKAL is now on:
Signal strength 98
SNR 30 db
AGC 21
Virtual channel not detected; comes up as channel 49.1
frank is offline   Reply With Quote
