The Winegard you're looking at will be OK to pick up KNSD or stronger. If you'd like to see XETV's eventual digital operation reliably, you should spring for the HD7698P. If the antenna does not have to look directly through the lines, you will definitely be fine. I'll let others comment to the situation of having the lines directly in the antennna's sight line.
