Due to your concrete construction, I would not recommend an attic install. It could work somewhat but not recommended.
The antenna that would do the best job for your reception is the RCA ANT751. You can try this in the attic, but If you are only interested in the stations at 287 degrees you could use a Winegard DS3000 (satellite pole) on the North side of your house aimed to 287 degrees magnetic. It doesn't need to be any higher than 10 feet or so. If you dont like the looks of that antenna, look at the Terk HDTVo on the same mount. To hook up two sets use a two way splitter 50 to 1000 mhz. If you use the RCA antenna, use no amplifier. The smaller Terk has a built in amplifier and you need to install the splitter after the amplifier power supply.
Both of these antennas include VHF channels. you only have one usefull VHF, channel 7.
