Old 31-Aug-2010, 1:39 AM   #1
wolfman334
Antenna help in SoCal
Hi everyone,
I'm about the ditch cable and I've just started researching antennas to try and pick up the local HD broadcasts down in San Diego. I'm very new to this so a little advice would be great.
http://www.tvfool.com/?option=com_wr...a362909c89b948
I'm in a two story home so the antenna could be roof mount which would put it around 20+ feet off of the ground. It would run one to two TVs. I have an AV panel with a built in amp but I've been bypassing it for my current cable feed.
There is a dish mounted on the 2nd story awning currently which would face in the correct direction I need. I planned on using the cable that is currently up there which is RG6.
I am in the mountains so I do have a bit of a terrain issue. The antenna I've seen suggested on these forums would be the Winegard HD-7696P which appears to have the range I need. My first question is whether that is correct or if I need a different antenna. My second question is whether I could get away with a fixed mount and still hit all three channel groupings by pointing at the 167 degree group.
There are also some pretty heavy duty power lines running directly behind my house which happens to be in the direction the antenna has to point. Will this be a problem?
Thanks in advance for the help!
Last edited by wolfman334; 31-Aug-2010 at 1:46 AM. Reason: Forgot one detail about power lines
wolfman334 is offline   Reply With Quote
