Old 8-Jun-2012, 7:38 PM   #1
chrx
Antenna Setup Opinions - S.F. Bay Area
Hi everyone. New member and first-time post. Glad to be here!
I have decided to cut the cord and have lined-up some gear that I think should get the job done.
First, here is the link to my location report:
http://www.tvfool.com/?option=com_wr...134993e772512b
Starting with my choice for the set-top box, the Zinwell ZAT-970A:
http://www.solidsignal.com/pview.asp...sku=7440900089
I currently have a Winegard HD-6000 that I have for FM radio reception only:
http://www.winegarddirect.com/viewit...D6000%29&post=
I plan to use it, coupled with an Antennas Direct DB8 UHF antenna on the roof, around 30-35 feet off the ground:
http://www.antennasdirect.com/store/DB8_HD_Antenna.html
I may, or may not need a rotor to get good reception from both San Francisco and San Jose, if I point toward S.F.
Any opinions on this?
Also, I plan to connect them with a Antennas Direct EU385CF and run a single cable to both my TV set-top box and FM receiver in the living room:
http://www.solidsignal.com/pview.asp...u=853748001705
Any recommendations on whether a standard splitter at the TV & radio will work best, or something more specialized?
Also, should I use an amplifier? I expect the cable length to be around 50 feet.
Thank you for any help here,
Chris O.
chrx is offline   Reply With Quote
