Old 8-Jun-2012, 6:17 PM   #2
I think the DB8 will have too narrow a forward beam. The new DB4e has very similar gain but wider forward beam specifications. Start with a beginning aim point of about 190° compass.
If you want to go after the signal from WVNY-ABC, you'll be needing to use an Antennacraft Y10713 or possibly a horizontally stacked pair due to the co-channel interference from CFCF on CH-12.
http://forum.tvfool.com/showthread.php?t=1024
