			If you don't have trees or large buildings between you and the stations, I would mount an RCA ANT751 above your roof line. This antenna can be mounted on a satellite "J" pole, such as the Winegard DS3000. Aim either 355 or 129 magnetic. See if one works better than the other. Use a Channel Master 3414 distribution amplifier. This has four outputs. Use a 75 ohm terminator to plug the one that is not in use. This will provide for expansion of your system, or use a single output amplifier and a three way splitter.
