Old 8-Jun-2012, 10:34 AM   #4
signals unlimited
Install an Antenna Craft U4000 four bay antenna. The 4 bay antenna has a wide beamwidth and should receive the PBS 42 and your locals to your East. To do this I would start at 67 degrees magnetic to confirm reception of PBS. If that works, but the stations at magnetic 100 don't, move the antenna direction towards 100 degrees a little at a time to see if you can locate a sweet spot for all stations including PBS. Mount the antenna on the East end of your home. If you can keep the antenna as far North(towards the street) as possible, to avoid the trees to your East.
To hook up your four sets use a Channel Master 3414 four way distribution amplifier.
Install a ground block in your coax run between the antenna and the entry point.
