Old 7-Jun-2012, 8:45 PM   #1
gawellman
Antenna recommendation for 37663 (East TN)
Hi there. I'm hoping to get some help for an antenna recommendation for nearby digital OTA HD channels.
Signal analyses:
15 ft: http://www.tvfool.com/?option=com_wr...13497d7e7d6f31
30 ft: http://www.tvfool.com/?option=com_wr...134921ca5a1522
45 ft: http://www.tvfool.com/?option=com_wr...13494efd96ffe3
Single-story home. Interior, attic, or roof installations are all possible.
Both PBS stations look problematic. We do watch PBS, so I'd like to pull in one or both if possible. Would also like to know whether the recommendation changes if I decide I don't care about PBS.
Existing Cable TV line goes through a 4-way splitter, then each line feeds a TV or HDHomeRun tuner. Broadband internet from cable provider comes in on a separate line from the pole, so I'm hoping to disconnect Cable TV and re-use the "TV" lines and use the antenna as a single source.
Thanks for the advice!
Greg
gawellman is offline   Reply With Quote
