Old 6-Jun-2012, 10:28 AM   #1
Blackbeen
Toledo OH reception & Channel Master 7777/7778 preamp question
I'm considering purchasing one of these preamps for use with my Antennas Direct DB4e:http://www.antennasdirect.com/store/DB4e.html
J-mounted outside a 3rd story window on a north side brick wall about 25-30' off the ground.
I'm in the 43606 area, my cable run is 31' to one HDTV. I do have a stations within 20 miles but experience severe break up on most of these local Toledo channels & since there are strong FM stations almost in direct line with them I'm hoping the FM filter might improve this issue. Also I'd like to improve reception with the channels 50+ miles away (Detroit), to note contrary to the TV Signal Analysis Ch 7 much of the time comes in as strong if not stronger than local ones. Would the Channel Master 7778 still be preferred? to reach Detroit channels &/or would a preamp even improve my current setup.
TV
FM
Blackbeen is offline   Reply With Quote
