Old 5-Jun-2012, 7:09 PM   #3
gossamer
WCBS is on the ESB in New York city, same as everyone else of import.
If you're looking at WFSB, it's out of range (Hartford, CT).
If you're having problems with one of the ESB stations while receiving the rest, relocate your antenna. you're likely getting a frequency-specific reflection (multi-path).
I'm still a little confused. In the TVFool graph, Real 33, which is says is WCBS-DT, appears to be northeast.
There's a WCBS-TV near the bottom of the list. Is that the one I should be referring to?
Is the frequency-specific reflection you're talking about the "co-channel warning" indicated in the graph? Otherwise I don't understand what you mean by frequency-specific reflection.
Thanks,
Dave
gossamer is offline   Reply With Quote
