Old 5-Jun-2012, 1:41 AM   #5
MisterMe
Originally Posted by Kbyrd View Post
I don't have an addition 20-30'. Would any 4 bay antenna work?
A 4-bay antenna has more gain. However, your problem is not lack of gain; your problem is lack of signal. You need to raise your antenna to 20'-30' so that you can receive the strong signal available to you at 20'-30.'
At 10,' the signal is listed as "2Edge." This means that it is scattered at least twice and possibly more from the transmitter to your antenna at 10'. A higher gain antenna will see a higher intensity badly scattered signal. Not to put too fine a point on it, but there is simply no reason to expect you to receive KDVR (RF32) with a 4-bay antenna mounted at 10' you you cannot receive KDVR (RF32) with your ClearStream2™ at 10.' You can, however, expect to have very reliable reception if you raise your antenna above the badly scattered signal area.
