Old 29-Aug-2010, 1:37 PM   #2
Tv reception
Put the ladder to the chimney , loosen the telescopic clamp , unfasten the telescopic pole from the strap clamps. The top section will slide in to the bottom section. With a helper on the ground it be easy to then let it tip over on to the ground level. . Or you can loosen the strap pipe clamps , get up on the roof , go to the high side of the roof chimney , get up on and sit on the chimney and have your helper loosen the telescopic clamp and then let the top section of pipe slide down and while sitting on the chimney do the work.
