With the mixture of UHF, VHF high and VHF low in analog and digital, and from so many directions, both near and far, the only set-up that makes sense would be an all channel Winegard 8200 antenna in a Channel Master 9521 rotor on the roof. I would not use a pre-amplifier as it may overload due to near by strong locals. If you are feeding more multipul sets and have long runs of coax, you should use a distribution amplifier.
