Old 3-Jun-2012, 6:01 AM   #8
Electron
ALL Questions and Answers and Information - Broadcast Tv Reception and More
Antenna rotators Are Not channel surfing friendly , must wait for antenna to rotate.
->->->->For reception All The Way Around The Compass with out the reception of WRGB and WVBK.
Install a Winegard MS2002 amplified antenna above the roof. <-<-<-<-
->->->->The MS2002 receives all directions , no rotor required.<-<-<-<-
And if you choose you can add the YA6260 as a SEPARATE Antenna system.
The MS2002 and YA6260 Will Not be combined on to the same coax.
The 2 Separate systems will be separate all the way to the location/s of the Tv/s and a remote control A/B switch will be at each Tv location to switch from one antenna to the other. http://www.radioshack.com , #15-1968 , or , http://www.mcmelectronics.com , #32-4425.
A/B switches Are channel surfing friendly.
