Old 3-Jun-2012, 5:09 AM   #2
MisterMe
You have ample signal strength even with that rabbit ears antenna. Before you purchase another antenna, understand that an indoor antenna is best located in or near a window so that it looks through the window toward the transmitters. The window should have a southeast view so that your rabbit ears can be aimed 132° magnetic or 42° south of east magnetic.
If you have no such location in the living space your townhouse, then you may be forced to try your attic. Again, you need a window or outside all with a southeast view. The RCA ANT 751 is a good inexpensive antenna that should work well if you have the space. If your space is limited, then consider the Antenna Direct Clearstream 2 Complete.
MisterMe is offline   Reply With Quote
