ALL Questions and Answers and Information - Broadcast Tv Reception and More
Reception of .
KCPQ-DT 13 FOX.
KWPX-TV 33 ION.
KSTW 11 CW.
Will require a Winegard HD7698P antenna with a Winegard AP8700 preamp installed no higher then 25 feet above above ground aimed at about 140 degree magnetic compass.
And preferably the HD7698P antenna height between 1 and 10 feet above ground , and lower then 10 feet is better.
Due to a reception phenomenon known as ground wave reception , due to the long distances and hills to the transmitters , 116 plus miles.
I can not say that reception will be reliable 100% of the time.
The only way to find out is try it.
