Old 3-Jun-2012, 2:04 AM   #1
mdemaiter
VHF LOS and UHF Single Direction Antenna Combo?
Hi All,
New to this and trying to figure things out...
Signal Report here: http://www.tvfool.com/?option=com_wr...1349d6964d7115
(link edit to work)
Setup:
Looking at an attic install (two storey home), with the TV in the basement. There will only be one tv in the house. No wiring, amps or antenna have been purchased/installed. Neighbourhood is mostly two storey homes, with some mature trees but nothing too large.
Channel Goals:
All LOS VHF (damn Canada not having things UHF). WPBS-DT, WWTI-DT, and WWNY-TV for sure, and if in the realm of possible WSTM-DT (NBC). It would be sweet to get more but I am guessing that will not be happening.
I'm mostly new to this so I guess I am looking for the following info:
1. Antenna recommendation (are there UHF/VHF combos)?
2. Will an attic install work? I'd rather not put up an outdoor antenna
3. Is there a requirement for an amp when running wires (co-ax?) from basement to attic?
4. Basic set up if multi antenna/amp is required as I am mostly clueless.
Thanks for the help!
Mike
mdemaiter is offline   Reply With Quote
