Old 3-Jun-2012, 12:04 AM   #4
Electron
ALL Questions and Answers and Information - Broadcast Tv Reception and More
This recommendation is based on the Current Plus Pending Applications Included reception of Digital Tv channels and Analog Tv channels.
Because of a unusual combination of channels in All Directions in All Three of the Tv bands.
UHF channel 14 thru 51.
For reception in all directions in the , green , yellow and red reception zones down to WRGB channel 6 CBS and This Tv.
I am recommending a unusual combination of antennas.
Installed Above the roof of the house.
Above the roof install and aim a Winegard YA6260 VHF low band antenna at about 350 degree magnetic compass , for the reception of Digital channel WRGB and WVBK-CA Analog channel 2 Vermont Outside Television.
Here is how to aim the YA6260 antenna , http://www.kyes.com/antenna/pointing/pointing.html.
And also above the roof install 2 Winegard MS1000 antennas.
One for the reception of the VHF high band channels of 7 thru 13.
And a second one for the reception of all the UHF channels.
The three antennas will be connected together on to one coax with a Winegard AP2870 preamp and HLSJ.
HLSJ =VHF high band and VHF low band Separator Joiner.
Connect the YA6260 to the VHF low port and a MS1000 to the VHF high port.
The other port of the HLSJ is connected to VHF input of the AP2870 preamp.
The second MS1000 is connected to the UHF input of the AP2870 preamp.
This setup combines all antennas on to one coax.
All antennas are installed above the roof.
Here are some above the roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com , Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
Here are some places to buy antennas and etc. , http://www.solidsignal.com , http://www.winegarddirect.com , http://www.amazon.com.
