Old 2-Jun-2012, 10:55 AM   #2
signals unlimited
The US stations are not going to work well with any indoor antenna. I recommend that you go with the directional Terk. If you can place the antenna in the North end of your home, and if your home in standard wood construction or has windows on the North side, the un-amplified antenna should receive the Canadian stations at 33 degrees.
