Old 2-Jun-2012, 3:39 AM   #5
morrison0880
Here is the more accurate report based on my address.
http://www.tvfool.com/?option=com_wr...134995e099a1e1
I see a lot of suggestions for the Winegard antennas. Are they that much better than the ClearStreams? The reason I chose that antenna initially is because of the low profile and the cleaner look. It seems to do a solid job picking up Milwaukee channels inside the home, with a room at ground level, so I assumed it would be fine for my installation? If so, I was considering getting the ClearStream 4 http://www.bestbuy.com/site/Antennas...ream&cp=1&lp=4 for the Chicago stations. I'm assuming the amplifiers you suggested will work for both?
morrison0880 is offline   Reply With Quote
