Old 2-Jun-2012, 1:38 AM   #6
ALL Questions and Answers and Information - Broadcast Tv Reception and More
This recommendation is based on the Current Plus Pending Applications Included Digital channels of the tvfool radar report.
On the balcony.
Install a Terk HDTVo antenna aimed at about 280 degree magnetic compass.
The best way to get the coax from the antenna to the Tv is the coax goes through a hole through the wall.
Here is another way to do it Holland 144823 flat cable. In the solidsignal search box type in , holland 144823.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com.
The tuner MUST SCAN for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Looking at the Pending Applications Included Digital Channels you see the groups of Tv stations to the , south/west , west , north/west , north , north/east.
Start with the antenna aimed at about 280 degree magnetic compass. The turn the antenna to about 0 degree magnetic compass. And all so scan for channels with the antenna in between those two directions. The game is to get as many channels as possible and also the channels you will like to watch.
The tuner Must Scan for the Digital Broadcast Tv Channels sometimes named the 'Air Channels' or 'Antenna Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
DO NOT scan for cable tv channels.
DO NOT scan for cable Tv channels.
