Old 14-Jan-2010, 5:22 PM   #4
mtownsend
WNGS is the only VHF station from Buffalo, so if you go with a UHF-only antenna, this is the one channel you might be missing.
When more of the Canadian broadcasters fire up their digital broadcasts, you may also find that some of them will remain on VHF channels too.
If WNGS is not immediately important to you, then you can probably just wait and see whether you want to add a VHF antenna to the mix.
