Old 30-May-2012, 4:23 PM   #11
meazz12
Originally Posted by Electron View Post
If a splitter is used , then put the preamp and preamp power supply and power inserter to the coax line that is between the antenna and splitter.
One more question.
So, the amp's power supply needs to be indoor. I was thinking of attaching the preamp out side at the roof level. Then run one coaxial to a box outside wall of the house because both coaxial for each TVs are already outside in the box. My plan was to put the splitter in the same box as well.
Any suggestion?
meazz12 is offline   Reply With Quote
