Thanks for all of the updates!
I think we've captured all the information you've provided.
Just a few things worth mentioning:
- The channel 46 Daystar affiliate is still using the callsign of KDTP-LD in the FCC records, so that is how it will show up in reports.
- It looks like KFPH-CA has a new digital transmitter on record. This transmitter will undoubtedly replace their analog transmitter, but since we don't know when that will happen, the analysis results will show both entries for now. If anyone can confirm that the switch has happened, then we can remove the analog record.
FYI, these changes should take effect immediately on any newly generated reports.
