Old 29-May-2012, 11:02 PM   #7
Why not just one antenna? Then, a passive 3-way or 4-way splitter (with a 4-way you'd have a 'test' port.) That gives you outputs to three CM3414's. (The CM341X type amplifier is powered by a wall transformer that uses an F type connector... so you can extend the power connection using RG-6 cable with standard connectors. If you need to power from the floor below, no problem.)
The CM3671 seems to be over kill in this situation. Are you absolutely stuck with an attic install?
