For KQET, KSBW, and all of the other stations at 126 and 164 degrees magnetic, you only need the RCA ANT751R in the attic aimed at around 145 degrees magnetic. If you want the stations from your Northwest you will need a much larger antenna mounted above the roof, with a pre-amplifier aimed in that direction. Since the stations at 126 and 164 degrees are very strong, they may come in off the rear of the Northwest pointed antenna. If not you will need to add the 751R at 145 degrees with seperate coax, and an A/B switch to select between locations.
