Your location has television transmissions in ALL 3 BANDS , VHF low band channels 2 thru 6 , VHF high band channels 7 thru 13 , UHF channels 14 thru 69.
VHF low band.
WBQM-LD Real channel 3
WNYZ-LP Real channel 6
WKOB-LD Real channel 2
WPXO-LD Real channel 4
WNYX-LD Real channel 5
VHF high band.
WABC-TV Real channel 7
WNET-DT Real channel 13
WPIX Real channel 11
WPXU-LD Real channel 12
WYXN-LD Real channel 9
WNJB Real channel 8
and ect.
The rest are UHF channels.
The HD7000R receives ALL 3 BANDS. And so does the HD7010.
The tvfool radar plot lists the Real channels and the Virtual channels.
REAL channels and Virtual channels.
REAL channels are what is actually being Transmitted and Received.
It is Important to know the Real channel so as to select the correct antenna.
Virtual channels in most cases is the Analog Tv transmission channel number that the Tv station was transmitting on before the change to Digital in the year 2009.
Many Tv stations have kept old Analog channel number even though the Tv station may or may not be transmitting on the same channel.
Reason: Channel Branding.
Here at tvfool and the advisors here at tvfool deal with Tv transmission and reception the way it Really Is.
Not the common useless jabber that one hears and reads every day about HD antennas and Joe told Omar that Wanda said she heard Henry say that the XYZ antenna gets him all the channels.
The instructions and directions that are give here at tvfool are in fact the real deal.
If you choose to go with what Joe told Omar , then the rest of the internet is loaded with Joe's and Omar's and all of the misinformation that one can acquire.
Reason: Deleting off-topic content
