Old 29-May-2012, 2:52 AM   #4
Electron
ALL Questions and Answers and Information - Broadcast Tv Reception and More
This is for WOWforgod.
Install a Winegard HD7082P antenna above the roof aimed at about 265 degree magnetic compass.
The HD7082P antenna is a ALL channel antenna , All channel antennas receive , VHF low band channels 2 thru 6 , VHF high band channels 7 thru 13 , UHF channels 14 thru 69.
Here are some antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
Install a Channel Master CM3418 - 8 way distribution amplifier. Put the CM3418 at a location that makes it easy to run a coax out to each Tv location. And at a location that also has electric power.
Do not put the CM3418 out in the weather.
A coax will go from the antenna to the input of CM3418.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.channelmasterstore.com , http://www.amazon.com.
