Old 28-Aug-2010, 9:56 PM   #4
John Candle
Tv reception
Is the house a 2 or even a 3 story house ? Is there a tower or windmill ? The reason I am asking is the higher the antenna is the stronger the signals is from Atlanta. Go to the >Start MAPS< part of tvfool and put in antenna heights of 20 , 30 , 40 , 50 feet , also select the current plus pending stations. The reference signal noise margin for a reliable reception is 0 NM (dB) , the higher the number the better , the lower the number the worse. . Ok this is with the latatuide and longitude reading. . The address of 1707 hiway 34 shows much higher readings and antenna hight is less important. . This is the way living in hilly country is. Even so it's still a good idea to get the antenna up to clear the trees.
