Old 25-May-2012, 5:13 PM   #16
hpdad
Yesterday, after posted question about the grounding, I searched the web like crazy so I have the very basic idea .
The thing is, the antenna location will be about 30ft from home electrical service ground, so I have to ground the mast/and cable on a new grounding rod then bond it with the main grounding rod with 6 gauge copper wire.
Can I ground them directly on the home electrical ground rod even 30ft away? People on web say if over 20ft apart, it should ground on separate rod then bond them.
hpdad is offline   Reply With Quote
