Old 25-May-2012, 4:03 AM   #4
AtLarge
It's not clear what the last term in the equation for #8 is representing. The same is true for the last two terms in the equation for #4.
That was my weak attempt at taking the total loss for unit #12 and adding it to unit #8 to guesstimate what the signal strength would be for #8.
Then supposing that the total for #12 & #8 would affect the signal before it gets distributed in unit #4 at the bottom of the coax run.
My example is overly simplified, it does not account for signals coming from multiple directions and it also provides only one outlet per apartment (with four spare ports).
Consider the following... http://www.dipolnet.com/basics_of_de...ems__bib05.htm
Overly simplified is good because that's exactly what I need. Now I just need to study and absorb what you wrote and that that link.
AtLarge is offline   Reply With Quote
