Old 24-May-2012, 8:35 PM   #12
AtLarge
Electron, thanks for all the help. It will be connected to 2 tvs. Probably one more later.
Originally Posted by hpdad View Post
What the difference between Tru and Magn degree?
Magnetic is the natural pull of the earths pole.
True is what you see on a map.
If I use the cheap $5 compass from WM, what degree should I point on?
I picked up a nice one at WM for $11. Orange rubber coated, digital, backlit, clock, and can be calibrated to your location to compensate for Mag vs. True. I believe your TV signal analysis gives you both readings so you can't miss.
AtLarge is offline   Reply With Quote
