Old 28-Aug-2010, 5:40 PM   #2
No static at all
No static at all's Avatar
Either the Winegard 6000 or the Antennacraft FM6 should work well for you if the desired weaker stations are in the same direction. I have personally used the Antennacraft & was very pleased with it's performance with stations up to 80 miles away.
If your desired stations are in various directions, the Antennacraft FMSS or Winegard 6010 may be a better choice. Either of these omni antennas should provide better performance then the 4228.
Mount the 2 antennas at least 4 feet apart if possible to eliminate any possible interaction between them.
