Old 23-May-2012, 4:49 PM   #5
Tower Guy
Originally Posted by hpdad View Post
http://www.tvfool.com/?option=com_wr...b1a8c549700a35
I am looking for out door antenna to get abc, fox, nbc, kcal....local channels.
Two years ago I got one from radio shack but no luck so I returned it. Which antenna should I get in order to get those channels.
I'd start with a question. Do you want channel 5 KRVD or 6 KREP? They are low band VHF stations that are located in different directions. let's assume that they don't matter to you, but you want all the stations from LA. I like to avoid rotators if possible.
There are two ways to go;
1. A single antenna such as the Winegard HD7698P with a AP8700 preamp.
2. Dual antennas 91XG UHF and Y10-7-13 VHF with an AP2870 preamp.
In either case you can add KREP with a Y5-2-6 and a HLSJ joiner.
