Old 23-May-2012, 1:36 AM   #3
Tv Antennas and Tv Reception
Here are some Tv stations that will be received.
About REAL channels and Virtual channels. REAL channels are the real and actual channel that is being transmitted and received.
The Virtual channel in most cases is the Analog channel the Tv station was transmitting on before the change to digital. The Tv station kept the old Analog number , It is known as Channel Branding.
It is Important to know the REAL Channel that is being transmitted and received so the Correct Tv antenna can be selected.
KABC-TV , REAL channel 7 ABC , virtual channel (7)
KNBC-DT , REAL channel 36 NBC , virtual channel (36)
KCBS-DT , REAL channel 43 CBS , virtual channel (2)
KTLA-DT , REAL channel 31 CW and Antenna Tv and This Tv , virtual channel (5)
KCOP-TV , REAL channel 13 Mynetwork , virtual channel (13)
KLCS , REAL channel 41 PBS , virtual channel (58)
KDOC-DT , REAL channel 32 Me-Tv , virtual channel (56)
KPXN-DT , REAL channel 38 ION , virtual channel (30)
KOCE-DT , REAL channel 48 PBS , virtual channel (50)
KCAL-DT , REAL channel 9 IND./CBS , virtual channel (9)
And many more Digital Tv stations/channels will be received.
It looks like KVTU-LP channel 3 is transmitting as a Analog Tv channel. http://americaone.com.
http://en.wikipedia.org/wiki/KMCA-LP ,
http://transition.fcc.gov/fcc-bin/tv...)&facid=130176.
Yes , Low Power , Translator , Repeater , Tv stations can continue to transmit Analog until , September of 2015.
Many , Low Power , Translator , Repeater , Tv stations have and are converting to digital and many have not. They have until September of 2015.
The Tv's Must scan for Digital and Analog Broadcast Tv channels.
Do Not scan for cable tv channels.
