Old 23-May-2012, 12:02 AM   #3
Electron
Tv Antennas and Tv Reception
As a test/experiment , aim the HD7696P antenna at about 137 degree magnetic compass.
To see if reception of the Macon stations are something to invest in.
If so then install a Second HD7696P antenna with a Winegard AP8700 preamp. The output of the AP8700 preamp will have no splitter for one Tv connection , a 2 way splitter for 2 Tv's connected , and a 3 way splitter for 3 Tv's connected.
It will be 2 SEPARATE Antenna systems the Atlanta antenna system and the Macon antenna system.
The 2 SEPARATE Antenna Systems WILL NOT be Connected Together On to One Coax.
The 2 SEPARATE Antenna Systems Will Be Separate all the way to the Tv or TV's. And a remote control A/B antenna switch will be at each Tv to switch from one antenna to the other. http://www.radioshack.com , # 15-1968 .
http://www.mcmelectronics.com # 32-4425 .
