Old 22-May-2012, 12:55 AM   #5
No static at all
No static at all's Avatar
Originally Posted by mrbleegs View Post
Is there any reason why i cannot receive the other 2 channels?
IMO, both channels are too weak for reliable reception with any attic antenna. If you can get the antenna outside you may see WJZ, but WBFF is highly unlikely with strong adjacent channel 47 right in your backyard.
Even the most tolerant pre-amp will worsen things. A distribution amplifier may help if more than one set will be connected. The Channel Master 3414 is extremely resistant to overload.
Do you see any signal from Baltimore's WUTB-24?
