Old 21-May-2012, 10:21 PM   #1
mrbleegs
Reception with attic antenna install
I am trying to receive some distant stations from an attic antenna.
TV Fool report:
http://www.tvfool.com/?option=com_wr...b1a8ea34751bda
Current setup is Winegard HD7694p with Winegard HDP269 signal amplifier. The antenna and amp are in my attic about 25 feet from ground level. I have one single RG6 cable run about 35ft to my downstairs tv. The Antenna is pointing south.
I would like to receive the Baltimore local channels, specifically WBAL (11.1), WMAR (2.1), WJZ (13.1), WBFF (45.1), WNUV (54.1)
Right now i have managed to receive WBAL, WMAR, and WNUV. I cannot receive WJZ or WBFF at all.
Is there any reason why i cannot receive the other 2 channels? Eventually i would like to setup 2 antennas - one used for the baltimore locals, and the other used for the nearby area locals. If i should be using a different antenna which should i choose?
mrbleegs is offline   Reply With Quote
