Old 19-May-2012, 2:20 AM   #1
kern2011
Very few channels, Help!
http://www.tvfool.com/?option=com_wr...30eed06b<br />
I am only picking up 4 channels and feel with my setup I should be getting more. I have the typical Yagi antenna, its big, I'd say 8ft long. It was on our house when we moved in. It's mounted on the roof with a tripod mount with a 10ft mast. I'd say its 25ft off of the ground. The antenna is connected with a radioshack matching transformer with 2ft of Rg-6 cable to a winegard AP-8275 amp. Then about 30ft of Rg-6 to a Channel Master 3214 4-way spliter with another 20ft of Rg-6 to the TV (built in digital tuner). The antenna is pointed at around 225 degrees (true north). I only get channels 8,13,23, and 49. I also get analog channel 61, I have no clue why, it is only static. Am I getting interference from something? Also I'm guessing my antenna is not the best choice for digital signal. Also one night I did a channel scan and also picked up 6,33, and 59 for about 30 min during that time analog 61 went away. Any help is appreciated, thank you in advance.
-Kern2011
kern2011 is offline   Reply With Quote
