Old 18-May-2012, 6:25 PM   #2
signals unlimited
One Pennsylvania boy to another, I have installed in that area and it is challenging, however since you are on the top, I can see no reason, even with some trees around that you should have any difficulty receiving the Altoona/Johnstown stations. Use a Channel Master 4228 HD 8 bay antenna and a Channel Master 7777 pre-amp mounted on the roof as clear of the trees as possible. Aim the antenna to 318 degrees magnetic, and with a DTV set or a converter box, scan for channels. be sure if you are using a DTV set that you configure it to receive antenna channels, not cable. If you travel near Harrisburg, you can pick these items and any cable ect. that you need at Cumberland Electronics. Call first 888-501-9658.
