The "J" pole should work provided it gives you a clear view towards the stations, if not you can move it. The "U" bolt on your new antenna may need to be spread a little to allow it to go over the J pole diameter, but most of the U bolts provided with antennas will work. Your satellite cable is compatable to OTA, but not the splitters. Replace them as recommended above.
