Old 17-May-2012, 5:13 PM   #4
Tv Antennas and Tv Reception
Or can do it like this , aim a Antenna Craft Y5713 at the north/west group of Tv stations.
And aim a Antenna Craft U4000 at the north/west group of Tv stations and then lift the metal clips that hold the reflector rods of the U4000 in the horizontal position and rotate the reflector rods to the vertical position , this gets the reflector rods out of the way so the , >< , shaped reception elements will receive both directions , the north/west and south.
Combine the 2 antennas with a UVSJ = UHF/VHF Separator/Joiner. Type the letters UVSJ in the solidsignal search box. . http://www.antennacraft.net.
No matter what Tv antenna/s is/are used the Tv/s Must scan for the Digital Broadcast Tv Transmissions some times named the 'Antenna Channels' or 'Air Channels' in the Tv setup menu because the Tv transmissions travel through the air from the transmitting antenna to the receiving antenna.
Do Not scan for cable tv channels.
