Old 17-May-2012, 2:57 AM   #12
gossamer
Originally Posted by No static at all View Post
You could try raising, then lowering the antenna in 6 inch increments to find the best vertical sweet spot for the problem channels(s). I have seen it make a noticeable difference in many situations.
Interesting. I can believe that. Depends on how the signal bounces of nearby surfaces, etc.
Turns out shifting the antenna to the southwest direction did improve RF44 at the expense of WNBC (RF28), which is in the southeast quadrant on my map.
Wouldn't CBS also broadcast from NYC? I'm in northern NJ, so northeast is upstate NY or CT.
WABC (RF7), is also directly in the southeast direction, and that picture is perfect. Is it just because it's a little bit closer that's the difference?
Obviously I'd like to avoid the rotor, and finding the happy middle place is my best option right now.
Thanks for hanging with me :-)
Dave
gossamer is offline   Reply With Quote
